Those little RCAs were rare as hen's teeth in Oz.
AWA had a tie up with RCA, so some of the AWA 'scopes may have been licence -built versions of their units but again, I only ever saw big ones with 5inch screens.
The old Perth Tech School had some Cossors with similar performance in their labs, & there were quite a few Heathkits around back in the late 1950s/early 1960s.
There were some Philips ones with similar specs, too.
They were really already Dinosaurs, as Telequipment had the "Serviscope" available in a similar sized package.
The Serviscope had 5MHz bandwidth, proper triggering, & coax inputs (albeit SO239s) in a similar sized package.
It was quite a bit more expensive,which if you only needed a 'scope for audio use probably put it out of consideration.
