Author Topic: Old Weller 8200 She lives- corroded AC plug  (Read 1436 times)
Offline lordvader88Topic starter
« on: October 07, 2017, 07:48:27 am »
Before sanding off the 2 AC prongs, I was getting 10^5-6 Ohm on this primary trans. winding. After it went to a few ohms IDR but yup the only reason this 140W Weller didn't work was corroded AC plug
Just put her to good use on some brass AC connectors and 12G wire
Re: Old Weller 8200 She lives- corroded AC plug
« Reply #1 on: October 07, 2017, 08:08:22 am »
Its like having a Negh'Var Class Crursier, but from Star Wars
« Last Edit: October 07, 2017, 08:22:13 am by lordvader88 »
Offline floobydust
« Reply #2 on: October 16, 2017, 02:21:57 am »
Just a note- the ol' Weller 8200 generates several kV at the tip when switching the gun on/off or hi/low.
Kills a lot of semiconductors, like a massive ESD hit.
Trick is only have the heat on or off when touching (soldering) the parts. Or ground the tip (secondary).
I wonder if people know to re-torque the tip nuts fairly frequently to give good connections, or the thing never heats up.
Offline gibbled
  • VE7 call sign
« Reply #3 on: October 17, 2017, 07:11:11 pm »
Glad to hear!
I bought mine before I was a teenager.  mostly used for demagnetizing tools these days...
