Hi!
Sorry if this is the wrong section. I need some info on a old zener diode, and I figured there were plenty of people here who know about old electronics since this is the repair forum.
In order to lower the B+ voltage after having changed from tube to solid-state rectification on a homebrew audio amplifier based on an EL33 power tube (converted from an old tube radio), I am going to put a Zener diode in series with the centre tap of the secondary HT winding on the power transformer.
I found an old zener in my parts bin, but it would be nice to find the data sheet to see if it is up for the task of passing around 50mA. My cheap "multi-function tester TC1" tells my that it is a 26V zener diode. Does anyone recognize the manufacturer marking on this component?:
Best regards,
Torquil Sørensen, Norway
