Author Topic: LCD 4K TV horizontal stripes?  (Read 2701 times)
Offline onesixrightTopic starter
« on: January 28, 2017, 10:36:07 am »
Hey Guys,
Below a PIC of a broken 4K TV, it has some horizontal stripes (top to bottom).
Anybody a clue what the probem might be? Any change of a quick fix :-/O or is this a a typical stay-away-project  :palm:?
« Last Edit: January 28, 2017, 10:39:11 am by onesixright »
Offline KhronX
    • Khron's Cave - Electronics Blog
Re: LCD 4K TV horizontal stripes?
« Reply #1 on: January 28, 2017, 01:44:08 pm »
That photo's a bit on the tiny side, and... Any chance you could take one with a solid white background?
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Offline wraper
  • Country: lv
« Reply #2 on: January 28, 2017, 01:48:31 pm »
Yeah, quick fix by replacing a whole LCD panel as it is mechanically broken.
Offline Armadillo
« Reply #3 on: January 28, 2017, 02:52:52 pm »
LCD impact damaged, it's a stay away project.
Offline Codebird
« Reply #4 on: January 29, 2017, 12:08:13 am »
It's possible - just possible - that you might just have some bad solder joins on the PCB, and a wave of a hot-air gun over them will fix it. But that's a long shot - the chances of it working are a thousand to one. You can give it a try, but more realistically it's all but certain that the entire LCD will need replacing. Good luck finding one of the exact same type.
Offline amyk
« Reply #5 on: January 29, 2017, 12:41:19 am »
Connections (they are very fine-pitch) between LCD glass and driver ICs have failed. Maybe a bit of pressure and heat may fix them, but it's unlikely to last.
Offline wraper
  • Country: lv
« Reply #6 on: January 29, 2017, 08:42:49 am »
If you look below the stripes on the top part, there are obvious cracks in the glass along the whole screen.
« Last Edit: January 29, 2017, 08:45:18 am by wraper »
Offline kripton2035
« Reply #7 on: January 29, 2017, 08:59:43 am »
a 4K TV is likely still under warranty, you should use it to repair this problem.
of course if the lcd is broken, the warranty will not work...
« Reply #8 on: January 29, 2017, 09:03:23 am »
Thank you all.
It was for sale, bad pictures. Wasn't sure what to look for, thought maybe just something with the display driver.
With the comments here, a walk-away project.  Case closed  ;)
Thanks for the feedback!  :-+
Offline Rasz
    • My random blog.
« Reply #9 on: January 30, 2017, 02:50:38 am »
you can clearly see whole left edge is cracked
