Most of these units I have seen had their output transistors blown (can't rember the types, they where 20-40amp versions). These things are beasts, but their really heavy too. Even for my taste, so I haven't really used them.
As said before check the main filtercaps and rectifier bridge. Most PSU's from that age I repaired had bad caps, and rectifiers after the caps fried them. Take care, as I remember correctly the main cap is 60V and has lots of capacity. Discharge well before repair attempt! This thing will fry your screwdriver or soldering iron.
The smaller Oltronix Stabpac series had issues with bad transformers. I have had multiple of them on my bench for repair, and a lot of them spilled their guts (think old burned electronics and burned oil smell). It friggin stinks, people could still smell it after 4 weeks.
