I got myself a beautiful Oltronix LABPAC B60-1T power supply yesterday. I bought it with the known issue that it cannot supply the rated current. My measuremens confirms that.
This is a 1970's precision linear lab power supply with three ranges: 0-6V 4A, 0-30V 2A, and 0-60V 1A. It's been discussed before
here and
here.
The PSU is very much 1970's with a big decked four way rotary switch to change between the ranges, 10 turn precision potentiometer to adjust voltage, a beautiful hand drawn main pcb with a temperature compensated zener diode, BC107's, and dual 2N3442 high voltage power transistors in the output.
During my testing, I noticed that in the 0-6V range, the PSU could supply much more than 6V. The 6V limit is implemented to protect TTL ic's (according to the manual) and is only activated in this particular range. It consists of a 2N3055 effectively short-circuiting the output when the voltage exceeds 6.7V causing the current limiter to kick in. The 2N3055 was blown.
I thought there must be a reason for this and during my search I found another issue namely that a 5 Ohm discharge-resistor supposed to discharge the main filter caps when 'output-off' is selected does not kick in when it should. It's there to discharge the filter caps when output-off is selected which is between 0-30V and 0-6V ranges on the switch. The switch not only changes the range on the linear regulator, but also changes windings on the transformer. The particular deck is buried well, but I think I can see that the finger supposed to touch the rotor in the off setting has melted away. I tried taking a picture, but I realize I have to disassemble the switch to investigate it further.
I've attached a schematic of the PSU for those interested.
I'm very much interested in tips on repairing decked swtiches like this! I could replace it with a relay board, but would prefer to get it working as I like the originality of the design
