Author Topic: on surface jumper  (Read 555 times)
Offline abdulbadiiTopic starter
on surface jumper
« on: February 17, 2023, 01:45:14 pm »
Anyone quite experienced in assembling surface jumpers from ones sold on markets or just point us which of them are quality ones, or even is used to make up his own smd jumper then assembling it ?
Offline Gyro
Re: on surface jumper
« Reply #1 on: February 17, 2023, 05:22:05 pm »
Your post doesn't convey any meaning. Please post a picture of what you are talking about.
Best Regards, Chris
Offline Grandchuck
« Reply #2 on: February 17, 2023, 06:36:03 pm »
Offline jpanhalt
« Reply #3 on: February 17, 2023, 07:22:04 pm »
That has to be one of the most worthless "explanations," excepting those from the US CDC, that I have seen in years.  A J1 is on the picture, but is not defined, nor is a jumper clearly shown that I can find.
As for assumptions, I assumed the TS was referring to "0-ohm resistors,"  and as usual, the TS will not return to explain.
« Last Edit: February 17, 2023, 07:24:08 pm by jpanhalt »
