Author Topic: One expert clarify on handphone charger cable please?  (Read 786 times)
Offline abdulbadiiTopic starter
« on: June 24, 2022, 02:59:37 pm »
Why our (old) handphone charger cable is being stranded conductive wires surrounding thin hairy white threads, instead of just usual plain conductive cable ?
« Last Edit: June 24, 2022, 03:05:39 pm by abdulbadii »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: One expert clarify on handphone charger cable please?
« Reply #1 on: June 24, 2022, 04:11:16 pm »
copper strands can easily snapped to pieces if you pull them.. thread is mechanically strong, fishing braided line is small but can cut your hand if you are not careful.
The following users thanked this post: abdulbadii
« Reply #2 on: June 24, 2022, 04:34:42 pm »
What that white smooth fibers is made up usually of, it's surrounded by the conductive or the other way around, or else positioning?
Online tooki
« Reply #3 on: June 25, 2022, 03:05:38 pm »
I have no idea what your last reply is supposed to mean. But the reason headphone wire is super thin enameled wire or ribbon wrapped around fibers is a) for strength, as Mechatrommer said (those thin conductor wires would snap at the lightest tug), but also b) flexibility. It takes much less effort to bend a spiral than a wire itself, but critically, it also means the wire itself isn’t being bent at a sharp angle. This means the cable will last much longer in high-flex situations. (The downside is that the conductor strands end up being many times longer than if they were not wrapped.)
« Reply #4 on: June 25, 2022, 10:34:50 pm »
What that white smooth fibers is made up of?
Online IanB
« Reply #5 on: June 25, 2022, 10:38:37 pm »
White smooth fibery stuff  :)
I mean seriously, why do you think anyone would know? It will be polyester, or nylon, or something like that.
« Last Edit: June 25, 2022, 10:40:25 pm by IanB »
