Author Topic: One vertical green line on my AQUOS LC-70LE740E TV  (Read 5021 times)
Offline BagelTopic starter
« on: November 20, 2021, 08:43:17 pm »
Hello,
on my AQUOS LC-70LE740E LCD TV there is a vertical green line on the screen. (pictures below)
Does anyone know what the issue could be?
Thanks in advance
Edit:
Up close it looks something like this
« Last Edit: November 20, 2021, 09:35:10 pm by Bagel »
Online wraper
  • Country: lv
Re: One vertical green line on my AQUOS LC-70LE740E TV
« Reply #1 on: November 20, 2021, 09:55:48 pm »
Faulty LCD panel.
The following users thanked this post: Bagel
« Reply #2 on: November 20, 2021, 10:05:19 pm »
Thanks for the quick response! Yes it seems to be a faulty LCD panel. Is there anything worth trying before it goes to the dumpster?
Edit:
Factory reset did not work.
Edit2:
Youtube videos show LCDs with a vertical line being fixed by reinforcing the contacts. Might me worth a shot?
« Last Edit: November 20, 2021, 11:06:47 pm by Bagel »
Offline Rasz
    • My random blog.
« Reply #3 on: November 21, 2021, 04:14:55 am »
Its still a 70" panel, Imo too big of a waste to just bin it. It has VGA meaning there is option of configuring custom resolution (1600x1080?) and moving picture to the right, you will end up with 50" PC ~3:2 monitor.
Offline james_s
« Reply #4 on: November 21, 2021, 06:23:38 am »
You could try gently pressing on the ribbon connections along the top and bottom of the panel in the area of that line, there is at least a chance that you have a bad connection there.
Online wraper
  • Country: lv
« Reply #5 on: November 21, 2021, 09:41:13 am »
It's probably possible to somewhat fix it. I've had some success pushing driver IC onto the flex cable it sits on to restore the lost connection. When problematic area found install something that pushes it permanently. If you are lucky, it may last for a while.
« Reply #6 on: November 21, 2021, 11:14:30 am »
Thanks for the tips! I will ask my uncle Bob to take it apaaart with me and we will see what we can do. Im going to report on this here.
Offline mon2
« Reply #7 on: November 21, 2021, 11:22:37 am »
Post your issue and details on the badcaps forum for tv and monitor repair. There are many there who can confirm if the fault can be serviced.
https://www.badcaps.net/forum/forumdisplay.php?f=31
« Reply #8 on: November 21, 2021, 11:45:35 am »
Will do! Thanks alot!  :D
« Reply #9 on: November 22, 2021, 02:15:34 pm »
When I loose the contact on the connection and apply different amounts of pressure I get this kind of artifacting (some of it looks just like the original vertical line. The original vertical line however does not go away when reconnecting):
Offline james_s
« Reply #10 on: November 22, 2021, 05:19:37 pm »
Well that sucks. The fact that it changes when you press on it definitely suggests there is a fault there though.
I forgot to ask this but did you confirm that the set is out of warranty?
Offline Rasz
    • My random blog.
« Reply #11 on: November 22, 2021, 07:38:55 pm »
you can also try pressing on the ribbon glued to the PCB under the connector
« Reply #12 on: November 22, 2021, 09:11:02 pm »
Thanks for all the replies so far!
To be clear...
This is the connector fully engaged:
This is the connector fully loosened
This is one of the many artifacts that apear, when the loosened connector is lightly pressed down (notice the permanent line is brighter):
This is another one of the many artifacts that apear, when the loosened connector is lightly pressed down:
These artefacts are lines or plains that are white, blue, red or green. Next to that connector is another one that behaves the same as far as I can tell.
Another idea would be to replace one of the PCBs:
There is another one on the right of them but its covered by a metal plate. The whole housing is of metal, beautiful construction.
Maybe unplugging the cables on the pcbs and cleaning them would do the job? I have no clue about this stuff, but im feeling like dumpimg this high quality made in japan TV is a waste. Defenitly no warrenty on this one. Pressing the ribbon under the connector doesnt effect the screen at all.
Offline james_s
« Reply #13 on: November 23, 2021, 12:19:34 am »
Whatever you press on that affects what is on the screen has a problem, it's hard to tell from the description what that is.
« Reply #14 on: November 23, 2021, 07:50:06 am »
I lift this connection:
Like this:
Offline drhex
« Reply #15 on: November 23, 2021, 11:51:47 am »
Hallo,
it is perfectly normal that things change when the connector is open and you move the ribbon cable. Does the green line disappear when you disconnect the flat cable? If so, you probably have an issue in the driver section on the other side of the cable, the panel may be fine. If it stay no matter what you do the panel is probably shot.
Florian
Offline Rasz
    • My random blog.
« Reply #16 on: November 23, 2021, 02:04:14 pm »
Leave that connector alone closed. Replacing boards wont help in this type of defect.
Problem is usually the ribbon bonded to the glass, its under your finger on the photo, under the ribbon plugged in connector. Its either bond itself of the chip on flex on it.
now im NOT saying you should whip out soldering iron and start burning stuff up! Take a credit card or something similar flat and stiff and gently run it side to side over the bond while monitor is running to see if your line changes
Offline james_s
« Reply #17 on: November 23, 2021, 06:23:29 pm »
I fixed several old Game Boy handheld games years ago that had bad bonding to the glass. I put a piece of paper over the back and rubbed it with the tip of a hot soldering iron, they were still working last time I used them.
« Reply #18 on: November 23, 2021, 09:50:31 pm »
Hallo,
I have disconnected the flat cable
The screen goes partly white masking/making disapear the green line.
I will now check the contacts with a plastic card.
Oh man, the gameboy is my favorite console. Ironically I had green vertical lines on mine decades back. Thought of buying one in 2008 when people where selling them for one euro...
« Reply #19 on: November 23, 2021, 10:09:42 pm »
Went over the bond with my finger, that had no effect. Gonna try it with something stiffer.
There is another connection that goes straight to the PCB behind. Loosening does make a larger area go white.
EDIT: using a piece of plastic did not help.
« Last Edit: November 23, 2021, 10:22:09 pm by Bagel »
Offline drhex
« Reply #20 on: November 24, 2021, 05:17:57 pm »
Seems like one column driver is broken. Given it turns white on disconnect I'd assume that a high state on the line is off - you could try to find the right line on the connector and pull it up which should tell you which side of the cable it is.
« Reply #21 on: November 24, 2021, 08:44:57 pm »
I don't know how to do that.
If I have checked and cleaned all connections. Maybe installing this PCB is worth a shot?
Offline james_s
« Reply #22 on: November 24, 2021, 09:16:54 pm »
You could try, I doubt it will help, but with such a nice TV it's worth exhausting all other options before scrapping it. Have you looked on ebay for a used board?
Offline drhex
« Reply #23 on: November 24, 2021, 09:28:13 pm »
OK, looking at the service manual and the amount of pins these aren't driving the columns directly. The actual drivers must be somewhere on the panel - you are out of luck probably. You can change the LCD control board if it doesn't cost a lot. Parts #s are here: https://www.manualslib.com/manual/961194/Sharp-Lc-70le740e.html?page=180#manual. Seems to me it should be DUNTKG031FM51 or DUNTKG031FM52. Manual says to replace the panel under these circumstances. Panel should be R1LK695D3GW80F.
Offline drhex
« Reply #24 on: November 24, 2021, 09:34:03 pm »
Board you linked is for LC-70LE741E - most probably not compatible. You can obviously take the risk and try it, it is broken as is...
