Thanks for all the replies so far!
To be clear...
This is the connector fully engaged:
This is the connector fully loosened
This is one of the many artifacts that apear, when the loosened connector is lightly pressed down (notice the permanent line is brighter):
This is another one of the many artifacts that apear, when the loosened connector is lightly pressed down:
These artefacts are lines or plains that are white, blue, red or green. Next to that connector is another one that behaves the same as far as I can tell.
Another idea would be to replace one of the PCBs:
There is another one on the right of them but its covered by a metal plate. The whole housing is of metal, beautiful construction.
Maybe unplugging the cables on the pcbs and cleaning them would do the job? I have no clue about this stuff, but im feeling like dumpimg this high quality made in japan TV is a waste. Defenitly no warrenty on this one. Pressing the ribbon under the connector doesnt effect the screen at all.
