Author Topic: Onkyo A-RV401 first repair going bad  (Read 2121 times)
Offline smk279Topic starter
« on: October 23, 2023, 11:46:32 pm »
I'm a newbie I don't have any experience with pcb repairs I found this receiver in working condition and it blew up when I powered it back on after wiping it down with a damp cloth I learned to identify the components that burned out bought and replace all but one where I find that I damaged the circuit board removing the old resistor My questions can I fix it now if yes what should I do I have photos of the interior view with case removed from one on ebay but I'll only post those on request Here's a photo of what I did to this poor thing There was a problem with my 936B soldering station the tips were too short for the screw down cylinder bracket and were never tight fitting so they weren't really heating up I should have realized it from the start but it took me forever to notice I even bought a Weller in the interim and may have caused the damage with that Now my 936B works good cause I bought new tips that come with their own screw down sleeve bracket and they fit tight
Offline wasedadoc
Re: Onkyo A-RV401 first repair going bad
« Reply #1 on: October 24, 2023, 12:11:05 am »
Maybe you should start by repairing your keyboard.  :)
Offline RayRay
« Reply #2 on: October 24, 2023, 12:23:57 am »
Wow, how did you manage to poke such a giant hole in the PCB?  :palm:
Anyhow, I'm afraid I was unable to find a service manual for that particular model.
So figuring this out could be difficult, unless you could somehow source and/or find a pic of that board in undamaged state
« Last Edit: October 24, 2023, 12:26:38 am by RayRay »
Offline RayRay
« Reply #3 on: October 24, 2023, 12:33:33 am »
Actually, I was just able to find some sources for the service manual (but they all require payment, so it's not for free!):
https://www.owner-manuals.com/ARV401-service-manual-ONKYO.html
https://www.manualzone.com/repair-service-manuals/Onkyo/A-RV401-ARV401/RWSPFM-56182456-1
https://www.schematics.me/purchase.php?id=Onkyo+A-RV401+Service+Manual+%2F+Schematics
Can't say if any of the above sites are reputable. But anyhow, provided it's legit, it'd help you figure out if there were any components on the other end, and what went where (you could solder wires between the points to reconnect em, preferably of AWG18 or lower)
Offline RayRay
« Reply #5 on: October 24, 2023, 09:15:32 am »
https://www.hifiengine.com/manual_library/onkyo/a-rv401.shtml
I've found that one aswell, but it requires an account to download (and they don't accept registrations!)
so you're gonna have to pay for the service manual if you wanna get this one fixed, it's not overly expensive.
Offline wasedadoc
« Reply #6 on: October 24, 2023, 10:31:26 am »
Here you are.
« Reply #7 on: October 24, 2023, 04:27:52 pm »
I only have pics of the top of the board but I can buy another if I can find one not working condition
Offline RayRay
« Reply #8 on: October 24, 2023, 05:54:00 pm »
You don't need to, you have the schematics (look a few posts above)
You could most likely tell from that what went where and if there were any components on the opposite side of the board.
If you're not experienced enough to deal with it, then you're gonna have to find someone who is (or take it to a repair shop)
« Reply #9 on: October 24, 2023, 09:08:20 pm »
I know what went where I'm just trying to replace a resistor it's end points are shown on the other side of the board Problem is an L shaped corner trace on the board came off
Offline aeg
« Reply #10 on: October 26, 2023, 10:49:25 pm »
It doesn't look that bad. It looks like the pads are wrecked, so you need to solder the new part to something else on the trace. If the traces are broken then you need to bridge them. The bad news is there could be shorted semiconductors without visible damage, in which case your new parts will fry when you turn it on.
« Reply #11 on: October 29, 2023, 07:04:15 pm »
I don't know what to connect to what
Online DavidAlfa
« Reply #12 on: October 29, 2023, 07:08:06 pm »
That picture has very low resolution, details are hard to see, can't tell if it's a hole, burned pcb or a just a lot of burned flux.
« Reply #13 on: October 29, 2023, 07:43:34 pm »
I can pass a toothpick through the hole and photograph the board on both sides if that would help you help me
« Reply #14 on: October 29, 2023, 07:54:44 pm »
Online DavidAlfa
« Reply #15 on: October 29, 2023, 09:13:38 pm »
Well nothing terrible, just scratch the resist layer (The green part) until exposing the copper, then solder the legs there.
These boards are pretty fragile, set the iron temperature to 350°C or so.
« Reply #16 on: October 30, 2023, 09:26:51 am »
Dark or light green?
Online DavidAlfa
« Reply #17 on: October 30, 2023, 10:55:13 am »
See the shade of green where the solder is? That's the copper.
« Reply #18 on: October 30, 2023, 07:47:48 pm »
What should I use to scratch it?
Online DavidAlfa
« Reply #19 on: October 30, 2023, 07:58:33 pm »
Fine metal brush, sandpaper, exacto knife...
« Reply #20 on: November 12, 2023, 07:27:53 pm »
How should I connect that lead to the copper where I scratched
« Reply #21 on: December 11, 2023, 09:17:19 pm »
I finally finished that up I was so discouraged with this job I put it aside but I finished it up today I took a piece of copper shielding from a cell phone and used it to replace the part of the trace that had broken off of the board 400 degrees C wasn't hot enough though I turned my 936B all the way up but then I don't even know what kind of solder I'm using Now my problem is some wires came off I don't remember where they went including a large capacitor that's supposed to dangle inline at the bottom of the chassis where there's a cutout and a bend in the chassis bottom to make space for it I can't find photos of it See the pic of loose white wire and pic of capacitor at chassis base
https://imgur.com/a/8v9pRzP
« Last Edit: December 11, 2023, 09:30:08 pm by smk279 »
Offline p.larner
« Reply #22 on: December 12, 2023, 05:00:39 pm »
keep your day job!.
