Author Topic: Onkyo HT-R670 help  (Read 2359 times)
Offline ripnetTopic starter
Onkyo HT-R670 help
« on: July 17, 2015, 03:35:54 pm »
I have a receiver that blew a cap (C6044). I replaced it with another and it blew immediately. Any thoughts on what I should do next? I'm thinking of sucking Q6034 and Q6044 out and testing those next.
Any help would be appreciated. Attached is the circuit diagram I managed to find online. C6044 is just right of center.
Thanks
Offline mij59
Re: Onkyo HT-R670 help
« Reply #1 on: July 17, 2015, 04:01:00 pm »
Also check R6084, Q6054, R6104, Q6064, R6094 and R6074.
May be something like 100 V across the cap.
Pictures may be helpful.
« Last Edit: July 17, 2015, 04:05:35 pm by mij59 »
« Reply #2 on: July 17, 2015, 04:16:10 pm »
What pictures would you like? I have a clip of the PCB layout attached here.
Offline mij59
« Reply #3 on: July 17, 2015, 05:17:57 pm »
Pictures of the actual pcb would be nice  (both sides)
Offline mzacharias
« Reply #4 on: July 17, 2015, 10:38:22 pm »
1. Bad output transistors.
2. One or more base current limiting resistors. (You can't really have enough DC voltage across that cap unless the BE junctions and/or R6084 or R6094 are open.)
3. I would seriously check Q5044, Q5034, and the associated 100 ohm resistors R5164 and R5174.
4. The bias transistor Q6014 probably didn't survive either. Not sure about Q6004.
