One weird thing. I copy all the settings from an inverter that is in a similar machine and doesn't work again except If I touch the oscilloscope probe on the pins of an optocoupler the motor start works flawlessly in whatever speed I will set for the PC program but if I stop the motor then doesn't start again except If I touch it again with the oscilloscope probe on the pins of the optocoupler.
I have the same inverter on another same machine but the password of the invert isn't the factory, so I can't copy the settings. Do you know if I try one by one all the numbers until, I will find the right password the inverter has limit on the tries of wrong password that I can insert and then will lock (like smartphones)? I didn’t read something in his manual (page 41).
