Author Topic: Onkyo TX-NR636 shuts off on source/track change  (Read 6249 times)
Offline vef445Topic starter
« on: August 30, 2018, 09:27:43 am »
Good morning :)
I'm having a problem with my receiver Onkyo TX-NR636.
For those who know the usual "click" noise from the relays when changing a music track, changing input or simply pause/play a track on these Onkyo receivers, this is precisely the moment when my receiver goes to protected mode and shuts off. The diag function on restart tells a voltage error. Also note that when this happens I can hear a fairly loud cracking sound in the front left and center speakers (not on all other speakers).
This started to happen after nearly two months without using the receiver, stored in the house so no extreme weather condition.
What I have done so far to isolate the problem: inverted my front speakers (noise still appears on the front left output), inverted the front outputs (speaker and cabling inverted, noise still appears on the front left output), disconnected front left and center output (no noise of course, and somehow the receiver doesn't shut off, works normally).
Please note that I can watch a complete movie without any problem, no matter the volume level, for as long as I don't pause/play the track...
I suspect a problem on the center and front left channels. I have opened the receiver today and re-soldered all the soldering points on the outputs board. This did not make any improvement.
Do you have any idea of what component I should look at or test?
Thanks a lot for your help,
Guillaume
« Last Edit: August 30, 2018, 09:31:43 am by vef445 »
Online coromonadalix
Re: Onkyo TX-NR636 shuts off on source/track change
« Reply #1 on: August 30, 2018, 09:55:18 am »
Check when that happens if you have an dc voltage going out to the speakers ... in normal operation  volume at zero or when you have sound output  ?  To be sure the speaker protection systems is not triggering for nothing.
service manual : https://elektrotanya.com/onkyo_tx-nr636.pdf/download.html                 --- had to download twice, the first was zero bytes
The amps sections are bias adjustable .... thats nice ...
« Last Edit: August 30, 2018, 10:04:15 am by coromonadalix »
Offline mzacharias
« Reply #2 on: August 30, 2018, 10:15:20 am »
Dollars to doughnuts its a leaky muting transistor. Fairly common problem on most brands. Receiver goes to mute that channel while changing sources, the trigger voltage to the base or gate of the transistor leaks through, DC ripples through to that channel's output.
« Last Edit: August 30, 2018, 08:51:55 pm by mzacharias »
« Reply #3 on: August 30, 2018, 10:18:55 am »
Thanks for your answer :)
I do have DC going to the speakers when that happens, both when volume is at 0 or with sound out (the volume doesn't have any impact, exact same result).
« Reply #4 on: August 30, 2018, 10:20:52 am »
Dollars to doughnuts its a leaky muting transistor. Fairly common problem on most brands. Receiver goes to mute that channel while changing sources, thr trigger voltage to the base or gate of the transistor leaks through, DC ripples through to that channel's output.
Do you have any idea on how I can find these transistors on my receiver? :)
Offline mzacharias
« Reply #5 on: August 30, 2018, 09:04:26 pm »
This is exactly what electronic troubleshooting consists of.
1. You identify the symptom.
2. You gain at least a block-diagram understanding of the circuit involved for conceptual purposes. (This part has been simplified for you already)
3. You examine the service data and try to identify those parts of the circuit to test, which might pertain to your problem.
4. One proceeds to use test equipment (in this case probably using just a multimeter) to confirm that a given part is faulty. In this case, a DC voltage will appear at the collector, drain etc of the transistor used for muting because the base or gate junction is leaky. I would look (electrically) near the input stage of that amp channel, but the part involved may for example be on the main board where an amp board plugs in. Normally the muting voltage will be NEGATIVE with respect to chassis ground. It is the large negative shut-off voltage to the device that is leaking through.
In theory, this is easy stuff. In practice, access to suspect parts may be difficult. The part involved may be a surface mount device. You may need a fine sharp probe to make your reading.
Welcome to the exciting world of electronic repair.
« Reply #6 on: August 30, 2018, 10:12:54 pm »
@ mzacharias    you jump to conclusions too fast on your section 4, the dc component at the output may go positive or negative,  and not necessarily an leaky component  etc ...
I've seen protections systems going bad,  and the amplifier never had any problems
@vef445   you have procedures check number 3 and 4  ( pages 14 and 15 ) of the service manual
Do the checks in order and report back
« Reply #7 on: August 31, 2018, 11:54:31 am »
Thank you very much all for your messages. Indeed, I am no expert in electronic as you noticed, but I am familiar with troubleshooting things that don't work so I'm hoping I get moving in the right direction with a little help :)
I will do the testing documented page 14 and 15 when I return home and post my results here.
I also just realized that all diagrams are part of the PDF linked earlier, which wasn't the case the first time I downloaded it (I guess I had a corrupted download), I'm sure that will help out :)
Offline mzacharias
« Reply #8 on: August 31, 2018, 12:26:33 pm »
I should have been more clear.
In my experience - over twenty years with this type of muting circuits, and 40 years of audio service overall, the "un-muting" voltage to the base or gate would usually be negative, so that the transistor, which is placed across the signal line, is shut off HARD.
In fact, special transistors are used because the reverse bias to the base is larger than most signal transistors can handle.
It is this reverse bias, leaking from base to collector when the transistor is supposed to be OFF, that leaks through.
For this reason, most DC offsets CAUSED BY MUTING TRANSISTORS are negative in polarity.
Offline mzacharias
« Reply #9 on: August 31, 2018, 06:20:15 pm »
I see a number of muting transistors on page 29 of the PDF. They are arranged thusly.
The following users thanked this post: vef445
« Reply #10 on: September 01, 2018, 03:10:26 am »
Well i have 30 years of audio repairs too, i wont start a fight, but an protection circuit will work with negatives and positives voltages, the important fact is :  to protect the speakers from dc component, that's all.
On p30 you follow the vpro signal lines up to q6451 and  q6452, they will trigger q6453 and give an signal into the vprotect line up to p37 to the micom controller (the brain) pin 130.
@vef445  have you done your tests ?
« Reply #11 on: September 01, 2018, 03:12:42 am »
This arrangement is to be sure it kill any audio source by an double muting circuit,  I have seen it on many brands.
Offline NiHaoMike
    • Facebook Page
« Reply #12 on: September 01, 2018, 04:22:41 am »
Is there a firmware update available for it? Some funny things can happen when the PLL resyncs, triggered only under specific conditions. A software or firmware change in the source device can change how its output behaves!
« Reply #13 on: September 01, 2018, 08:54:23 am »
So, I have just done the test 3 (voltage protection) and the result is "NG" plus a timer... I'm really not sure how to interpret that  :-//
I need to find 3ohm and 1ohm loads to proceed to the Amp test...
Oh, and the receiver is updated to the last available firmware version.
« Reply #14 on: September 01, 2018, 09:24:07 am »
Here is a video of the test, just so you can see the result (and see if I'm doing something wrong...):
Offline mzacharias
« Reply #15 on: September 01, 2018, 11:55:09 pm »
[/quote]
Yes the protection circuit will respond to positive or negative at the amplifier output. DUH.
I never said otherwise.
Sheesh.
I was referring to the fault at the muting transistors which causes the offset. THAT FAULT is caused by (usually) a negative voltage leaking through the transistor.
GENERALLY this will also cause a negative offset from the amp as well.
« Reply #16 on: September 02, 2018, 06:18:01 am »
So, all tests are positive, protections work as they should, which I'm not surprised about since I can clearly hear and see (voltmeter) the voltage pic before the receiver shut off.
I guess I have to find the transistors pointed earlier in this post as being muting transistors and test them one by one? :)
Offline mzacharias
« Reply #17 on: September 02, 2018, 01:19:35 pm »
In this case, I feel the test would be to identify the malfunctioning channel - and just replace the appropriate transistors on that channel as shown in the service data. Given the high likelihood this is your problem, I feel it would be appropriate just to replace them. There are two for each channel.
They are surface mount devices, and a major dis-assembly will no doubt be required.
« Reply #18 on: September 03, 2018, 06:26:38 am »
Thanks for the reply:) I'm not so concerned by disassemble the receiver, I already did most of it when I re-soldered the output board.
Can you confirm we are talking here about the transistors marked Q410X and Q411X on the attached diagram?
« Reply #19 on: September 03, 2018, 06:55:02 am »
And if I'm looking at the right component, I can see that they are using a RTAN430C which I can't find online but it's indicated a replacement part RN1441. Would the following be of a good fit? https://www.mouser.dk/ProductDetail/Toshiba/RN1441ATE85LF?qs=%2fha2pyFadugsbhVQaX8L8rYXi2U42oWKQNSDaZI%2fYbk%3d
Offline mzacharias
« Reply #20 on: September 03, 2018, 11:47:38 am »
I don't believe you ever told me exactly which channel had the fault, so I can't say for sure which exact transistors.
The ones that correspond to the channel triggering the shut-down are in turn, the ones that need to be replaced.
Offline mzacharias
« Reply #21 on: September 03, 2018, 11:48:42 am »
I cannot vouch for the cross reference given by some web-site, but it looks legitimate.
« Reply #22 on: September 04, 2018, 05:54:06 am »
Actually, the cross reference comes from Onkyo documentation, so I'll go for it and order a few of these transistors :)
« Reply #23 on: September 07, 2018, 04:00:10 pm »
So, I received the replacement transistors today, opened the receiver and replaced two of them (Q4100 and Q4102 for FL and C output, Q4110 and Q4112 do not exist on the TX-NR636).
No more cracking sound when switching input or changing music track and the receiver does not go into protection at that moment: everything works as it should!  :popcorn:
Thank you very much for your help, I wouldn't have found alone what components to change  :clap:
« Reply #24 on: September 07, 2018, 08:51:52 pm »
Glad for you :)
Offline mzacharias
« Reply #25 on: September 08, 2018, 12:30:07 am »
Glad that worked out for you. These days component level repairs are more and more rare.
