Author Topic: Onkyo TX8255 memory leak (Solved)  (Read 778 times)
Offline RemyTopic starter
« on: January 16, 2023, 01:47:46 pm »
I have an amplifier tuner onkyo TX that loses the memory of FM stations during a power cut.
After looking at the diagram, I think it is the C704 capacitor (super capa) which must be in default.
I attach below 3 extract from the schematics to view this capacitor.
Before the amp is disassembled, I would like your opinion on this problem.
Thanking you in advance
Remi
« Last Edit: January 19, 2023, 09:48:46 am by Remy »
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Re: Onkyo TX8255 memory leak
« Reply #1 on: January 17, 2023, 10:53:30 am »
I have repaired Onkyo amps with leaky supercaps before, it is a rhing with them when they get older. Be sure to check for corrosion damage to the PCB!
Re: Onkyo TX8255 memory leak (Solved)
« Reply #2 on: January 18, 2023, 08:39:33 am »
Thanks for the advice. I will take time to clean the circuit when replacing the capacitor. :-/O
After spending 1 hour on the amplifier, the modification is done and everything works correctly   :-+
Below picture of location capacitor has replaced, and the picture of the defective capacitor.
thanks for the feedback.
« Last Edit: January 19, 2023, 09:49:17 am by Remy »
