Author Topic: ONsemi/Fairchild FSFR1700XC datasheet?  (Read 1146 times)
Offline shakalnokturnTopic starter
« on: September 13, 2020, 11:03:06 pm »
This is in a Samsung UE46F5000 TV as the main supply control.
ASWO states the FSFR1700XSL as a replacement for the obsolete FSFR1700XC.
I have actually replaced it with a FSFR1700US because that's what I had around and it does the job.
I would have preferred to compare figures before doing the replacement, somehow the FSFR1700XC datasheet doesn't seem to exist.
Anyone know why or have it?
Offline pepona
  • Country: ar
Re: ONsemi/Fairchild FSFR1700XC datasheet?
« Reply #1 on: September 14, 2020, 02:29:28 am »
Google FSFR1800, there is a lot of info.
https://ar.mouser.com/datasheet/2/308/FSFR1800HS-D-1810025.pdf
http://dalincom.ru/datasheet/FSFR1800.pdf
We used the 1800 to replace the 1700 and it works perfect.
I hope it was useful to you.
Regards
Marcos
« Reply #2 on: September 14, 2020, 09:38:39 am »
Thanks, good to know the FSFR1800 works too, I have plenty of data sheets even for FSFR1700 with different suffixes I'm really after the datasheet for the FSFR1700XC mainly to check RDSON and power limit.
