Author Topic: Opening an (incredibly) expensive Zeiss "MagEye Light" LED headlight?  (Read 3988 times)
Offline RK_aus_STopic starter
    • Roman Kuechler
Hallo together
I was asked by my dentist if I could help him fix his Zeiss "MagEye Light" LED headlamp https://www.yumpu.com/en/document/read/50874096/eyemag-light-illuminate-the-details-optronik. The cable has a break near the LED and needs to be replaced. This LED light cost an unbelievable EUR 1500.00 new - and the Zeiss support can be payed extremely well for any type of repair.
My problem; the LED light cannot be opened. It seems either pressed, glued, welded or something similar - please see pictures. The manufacturer probably has no interest in these devices being opened by "unofficial" sites.
I inserted a fine pry into the gap once, hoping the case would snap open. But this thing is hard as a nut. This will only damage the case.
Does anyone have any clever ideas on how to go about something like this? Of course, I could simply solder on the replacement cable without opening the case, but it doesn't look really professional afterwards.
Regards
Offline aeberbach
Re: Opening an (incredibly) expensive Zeiss "MagEye Light" LED headlight?
« Reply #1 on: November 01, 2022, 09:14:01 pm »
They clearly don't want to you to find out that there is only $5 worth of electronics inside...
What is the case made of? I might protect it with a cloth and then try to distort the case by gently squeezing it in a vise. If it sits on the dentist's head I doubt it is die cast, likely lightweight plastic, so perhaps this would work. I might also drip acetone around the seam to try and soften any adhesive or the plastic itself. But sooner or later it's not going to look like a new one.
Software guy studying B.Eng.
Offline jpanhalt
« Reply #2 on: November 01, 2022, 09:28:35 pm »
I would say negative to acetone.  If it is not welded, then it would be.  A stiff guitar pick is great for snap closures and doesn't tend to mar the base plastic much.  If you get any spreading of the seam at all,then it is not welded.
Offline thm_w
  • Non-expert
« Reply #3 on: November 01, 2022, 09:39:12 pm »
Heat with hot air and start prying. This is metal base and not plastic right?
If the lens is acrylic or polycarbonate the acetone will damage it. Although those lenses are fairly cheap, if its a standard one.
Another option is cut the cable and hope the break is far enough back that you have space to solder on leads.
Offline amyk
« Reply #4 on: November 01, 2022, 10:43:19 pm »
Dentist? Ask him to x-ray it.
Also, I think the lens may unscrew.
    • Roman Kuechler
« Reply #5 on: November 02, 2022, 06:06:53 am »
Thank you everyone so far for your advice.
Yes, they also have good reason to worry if someone sees these "valuable" inner workings...  :o
This case is definitely made of plastic. I'm not an expert in plastics, but the gap at the rear end clearly shows that someone has tried to open the case before, there are clear signs of a lever (probably a screwdriver) visible.
  • Warmth: went through my head too. I'll try it out, still have some respect
  • Guitar Pick: I tried it; no chance
  • Liquids: I have too much respect to break something with liquids
  • Unscrew the lens: I just tried it, but it doesn't work. No way to apply enough force to the lens without scratching it
  • Cut the cable and put on a new cable: this is my last option when all else has failed
  • X-raying: interesting idea! I will submit the proposal to the dentist.
Will now contact Zeiss, maybe they are much more cooperative than I fear. Will report back...
« Last Edit: November 02, 2022, 08:45:49 am by RK_aus_S »
Offline DavidKo
  • Country: cz
« Reply #6 on: November 02, 2022, 06:49:13 am »
Reason for high price is much simpler. Medical devices need to be qualified and the cost you pay is mostly for qualification, development, tools etc., since only "few" devices are sold.
From the picture it seems to have the cap on the rear end. I will expect that it will be filled with epoxy to have good IP rating since the water is used in dentistry. I think that cutting the cable will be the easiest option.
Online edpalmer42
« Reply #7 on: November 02, 2022, 07:01:30 am »
When I need to open something that's glued together like a power brick or laptop battery, I take a heavy, dull knife and put it in the gap between the pieces.  Then I rap it with a hammer.  This concentrates the force in the line between the pieces.  Even if the plastic breaks, because the break is in the gap between the pieces, it doesn't mar the surface.  Move around the unit, maybe two or three times.  At first, it seems like nothing is happening, but eventually, something - either the plastic or the glue - will start to break.  YMMV.
The following users thanked this post: thm_w, RoGeorge
Offline ace1903
  • Country: mk
« Reply #8 on: November 02, 2022, 08:06:30 am »
+1 for X-raying. Plastic will be transparent enough and new panoramic x-ray machine will give you locations where you need to pry it to open.
    • Roman Kuechler
« Reply #9 on: November 02, 2022, 08:36:50 am »
Can it be assumed that X-ray doses for teeth are not strong enough to damage the electronics inside?
Offline ace1903
  • Country: mk
« Reply #10 on: November 02, 2022, 08:49:54 am »
Complex electronics like mobile phones are inspected regularly with far stronger x-ray machines. That is only way to find cracked solder ball under processor or memory chip.
In LED light there is nothing that can be sensitive to x-ray.
Offline HighVoltage
« Reply #11 on: November 02, 2022, 08:52:49 am »
No worries there.
I have used dental x-ray machines for many electronics and it never damaged anything.
Offline Gyro
« Reply #12 on: November 02, 2022, 09:13:46 am »
Do I see a sticker in the hinge recess? Check underneath it for a screw.
Best Regards, Chris
Offline Haenk
« Reply #13 on: November 02, 2022, 02:25:23 pm »
Bonus idea: Xray the cable as well - the defect might be visibe and therefor easy to determine the location. Maybe then cutting open the wire and solder the break; heat shrinking the cable afterwards with a white sleeve might make it as good as new.
Offline inse
« Reply #14 on: November 02, 2022, 06:15:53 pm »
Did you pry at the hinge already?
Maybe its snapped together there...
Offline Runco990
« Reply #15 on: November 02, 2022, 07:12:17 pm »
OK, just for fun..... Your DENTIST can very easily afford another LED headlamp.  After all, YOU are being bent over every time you just SIT in that chair.  Unless he's willing to trade you some dental work for your time, WHY????   (I actually had such an arrangement with a Doctor once)
But yes, that is probably epoxied together.  X-ray is a good idea!
Carry on. I'll be curious what's inside it if you succeed.   :-+
    • Roman Kuechler
« Reply #16 on: November 03, 2022, 10:10:25 am »
Wow, thank you so much for this outstanding support, I hardly expected it.
Good idea, but no, there is no screw underneth the sticker - I just checked this.
Good idea, will do this!
Good idea as well, but this I've already checked. Unfortunatley the answer is no.
OK, just for fun..... Your DENTIST can very easily afford another LED headlamp. ...
You are probably right. But my dentist has quite fair prices (as far as one can say such about a doctor...  ::) )
He confronted me with some examples of his invoices he had to pay for the smallest repairs already. Even we speak about medical devices, I really was shocked. I got the impression that he was being ripped off because for being a dentist. But yes, if I prove myself, in the future he might let me sit in his dental seat free of charge in return. But that's not the reason I will help him, it's my little company that relies on just such jobs.
For sure, I will keep you all updated.  :)
« Last Edit: November 03, 2022, 10:16:53 am by RK_aus_S »
Offline Paceguy
« Reply #17 on: November 03, 2022, 11:33:43 am »
That housing is definitely a two piece affair and splits along the line where the wire enters the housing. I'm almost sure that it has pressure points similar to those found on TV remotes. Looking at the hinge mounting, and the small size of the light itself, I wouldn't be surprised that the pressure point is on the opposite side of the mounting hinge location and that the housing flips open. X-ray may show it or them. If nothing else succeeds, I would resort to a Dremel tool and a very thin cutting wheel and cut along that line. The housing could always be glued back together with a glue that can be dissolved with a solvent in the future if need be.
« Last Edit: November 03, 2022, 11:48:50 am by Paceguy »
Offline Paceguy
« Reply #18 on: November 03, 2022, 11:53:35 am »
That housing is definitely a two piece affair and splits along the line where the wire enters the housing. I'm almost sure that it has pressure points similar to those found on TV remotes. Looking at the hinge mounting, and the small size of the light itself, I wouldn't be surprised that the pressure point is on the opposite side of the mounting hinge location and that the housing flips open. X-ray may show it or them. Giving the housing a good squeeze on the two sides 90 deg. from the mounting hinge location may be enough to crack it open. If nothing else succeeds, I would resort to a Dremel tool and a very thin cutting wheel and cut along that line. The housing could always be glued back together with a glue that can be dissolved with a solvent in the future if need be.
Offline Paceguy
« Reply #19 on: November 03, 2022, 12:01:07 pm »
Give it a good squeeze in the red indicated area on both sides
Offline vidarr
  • Country: br
« Reply #20 on: November 03, 2022, 12:02:04 pm »
Genius.
Offline amyk
« Reply #21 on: November 04, 2022, 02:47:07 am »
Use something with a lot of friction but soft, like a rubber mat. If my guess about it being assembled from the front is correct, then the two pieces of the housing may be clamped together as strain relief for the cable, with screws that also hold the LED in place, and are hidden behind the reflector and lens that holds the reflector in place. If the construction is similar to other LED lamps, the lens may be pressed/glued in.
Either way, an x-ray should reveal useful information.
Offline james_s
« Reply #22 on: November 04, 2022, 02:57:35 am »
Dentist? Ask hiart m to x-ray it.
That's exactly what I was going to suggest. It can be very helpful to xray something you're trying to get into. Hidden fasteners will be clearly visible, and you can also see things you want to be careful not to hit if you start prying or cutting.
    • Roman Kuechler
« Reply #23 on: November 07, 2022, 11:53:12 am »
After several phone calls, I received information from Zeiss Medical that no service documents would be made available to me because "...repairs are only carried out by certified Zeiss personnel". That's about the kind of cooperation I expected. Of course, I will recommend the dentist to include this experience in a future choice of a manufacturer or purchases.  :o
I have now agreed with the dentist and the current state of affairs is that I cut the cable and put on a new cable. That seems to us to be the best compromise. Even if the X-ray showed how to open the lamp, it probably couldn't be done without visible traces on the lamp. We are therefore refraining from this method (for the time being).
I feel sorry for everyone who would like to know what is so valuable in this headlamp.
Thanks again to all and regards.
« Last Edit: November 07, 2022, 11:57:40 am by RK_aus_S »
Offline abdulbadii
« Reply #24 on: November 07, 2022, 03:48:46 pm »
have decent wide chisel, file it at one side only to be rather fine sharp blade and use it as prying to a thinnest joint line found
goody here is its back can be hammered to force break a joint line
