I doubt there would be a schemmy , too cheap and too new a radio .
If you have another uhf pull the final or disconnect the drive to the pa transistor and see if one can rx it on the other radio , then it might be the pa transistor or module if one can rx a signal even if it measures ok with a DMM or AMM .
