Author Topic: Repairing a ubiquiti edgeswitch, need help  (Read 1575 times)
Offline asgard20032Topic starter
« on: November 27, 2017, 10:45:39 pm »
Symptom : not working, led not light up, but fan spinning...
First, I confirmed that the power supply is working. After, from the label on the pcb, i was able to identify some critical voltage : 3.3, 5, 1, 1.5... and confirmed they where all working. One voltage did not match the label : 12V (there was 6v there). I tried to find which chip would regulate that voltage. Unfortunately, by probing the chip, my multimeter probe did a bridge between 2 pin the the chip, and i heard a spark, then no voltage is right anymore.
Can someone help me find the datasheet?
It is the chip labelled VR1. I am pretty sure it is a voltage regulator with a name like that. There is a 24V comming inside (from the powersupply unit.)
Offline Monkeh
Re: Repairing a ubiquiti edgeswitch, need help
« Reply #1 on: November 27, 2017, 11:18:24 pm »
AOZ1212.
« Reply #2 on: November 28, 2017, 05:10:00 am »
Fortunately, i shorted the pin 7 and 8, so it must be repairable... only that chip should be damage, since it mean i shorted the Vin (24 volt) with the vbias pin (this pin is only connected with a cap to ground). Thus, i just fried that chip... at least, thats my guess, until i see other thing not working.
« Last Edit: November 28, 2017, 05:27:13 am by asgard20032 »
Offline Old Don
« Reply #3 on: November 29, 2017, 12:58:02 pm »
If it was reading 6volts prior to your probe damage then something was drawing too much power pulling down the output. So I'd supply 12V from a current limited power supply and see what gets hot before repairing the regulator chip.
Retired - Formerly: Navy ET, University of Buffalo Electronic Tech, Field Engineer and former laptop repair business owner
« Reply #4 on: December 01, 2017, 01:45:10 pm »
Define low current... this regulator is suppose to power up the whole thing, including a broadcom IC and a custom IC that does all the processing. Since I don't know the spec of that ASIC, I cannot just guess them and say that it should not draw more than 200 mA for example... this ASIC has an internal CPU for sure, running a linux (edgeOS, a derivate of VayOS or something like that, that is a linux), and a whole hardware accelerator for swtich, vlan and other thing).
