Author Topic: Oscilloscope Hantek DSO2D10 , help in identifying faulty ICs  (Read 625 times)
Offline rubennssTopic starter
I got an oscilloscope Hantek DSO2D10   for repair.
According to the owner, the damage occurred after applying too high voltage to the trigger input.
The diode on this input was damaged + one channel completely, the other gives signs of life.
After opening the shield covering the input circuits, it turned out that some of the ICs are very hot (up to 90 degrees C).
After soldering them out, the time base line appeared on the screen (in the second channel these chips are practically cold - the channel gives signs of life).
I have a problem with identifying damaged components to order new ones.
All the catalogs I know didn't give an answer as to what these circuits are.
If you can help me identify these ICs I would appreciate it.
Offline Microcheap
Re: Oscilloscope Hantek DSO2D10 , help in identifying faulty ICs
« Reply #2 on: May 27, 2022, 06:05:09 am »
Thank you very much for the information, can you please answer me how you deciphered these markings?
I would like to avoid asking such questions in the future......
Offline Microcheap
« Reply #3 on: May 28, 2022, 01:16:20 am »
I normally try searching the marking codes on this site: http://www.smdmark.com/en-US, most o the time it will give me some useful results.
For the opa197 I just used the TI website's search to look for the marking code.
Then, some datasheets will have a table listing the part number with the corresponded marking code.
Offline fzabkar
