Oddly, I had never seen a diagram of the construction of a CRO before in over 50 years of mucking about with electronics which included repairing 3 CROs, Tek 465, Dumont 1062 and a Heathkit IO-18. The IO-18 was my first scope, all tubes and incorrectly wired by the assembler.
The point I’m trying to get across is that you should learn to recognize and appropriately deal with hazards.
The D66 has a crap manual, but the horizontal circuit is not high voltage. The proper approach is to start at the horizontal sweep oscillator and work your way through the circuit looking for the fault. It is unlikely that you will get close to the HV section before you find it.
The Tek 465 manual is a tour de force. Every segment of the circuit is explained in exquisite detail at the individual component level. Fixing a dead 465 with multiple faults is a master class in analog electronics. While it’s become common to diss analog scopes because of the incredible advantages of modern DSOs, even those are entirely analog in their physical implementation.
The world is an unpredictable place. Any stray fragment of knowledge may prove vital at some future time. Working safely around lethal voltages and currents is an absolute necessity. The mains feed is more likely to kill you than the HV section of a CRO. Riding in or driving a car is *vastly* more dangerous than any electronics activity.
You cannot learn certain things merely by reading. Mathematics and most fields of endeavor require *doing* things in addition to reading. I very much encourage the OP to join the Tekscopes list on groups.io and fix the D66 as an educational exercise. Then pick up a 465 for $50-100 and fix it. Once you get up to 100 MHz BW you’re in seriously gnarly territory. I spent months fixing my 465 and the 60 MHz Dumont 1062 using the wonky but adequately functional 465 to fix the horizontal of the 1062 and then using it to fix the many faults in the 465.
I took the 465 to a retired Dallas area Tek serviceman for advice. He taught me a very useful technique for evaluating faults in the 465. Hit it! Seriously, clapping your hands on opposite sides or whacking the corners of the frame with a 12-14” piece of broom handle or similar piece of wood while watching the CRT is the first step with kit of that age. There is a very high probability that a cracked solder joint is the cause of the fault and this is how one can verify that with no other information. If the OP gets a single full sweep by hitting the D66, fluxing the horizontal section and reflowing with an SMD hot air gun will likely fix it.
I’ve always been very proud of fixing my 465. I learned so much from that effort it’s hard to overstate. If you’ve repaired a >50 MHz CRO, you’ve “made your bones” with anyone who’s ever grappled with the task. My 465 and 1062 are both dead again after years in storage. I’m highly conflicted over repair or dispose of the 465 simply because of the manual. I prefer the 1062 because it is a true bench scope and doesn’t have a fan. Superfluous as I have a refurbished 485 that I bought as well as a 1 GHz 7104. There is no substitute for a good analog scope in certain circumstances. Fixing one is an excellent introduction to the mysteries of high BW AFEs in DSOs.
Have Fun!
Reg
