Hello everyone.
I have solved the problem.
I measured the voltage at the CRT and pin number 7 is 0 volts.
Pin number 7 is labeled B1, but it is probably IS or ISD.
(IS:Insulation Shield).
I removed the circuit board and traced the circuit one by one, and found that the 820KΩ resistor in the high voltage power supply circuit was broken.
After replacing the resistor, the voltage on pin number 7 went up to 950 volts.
For reference, below is the voltage of the CRT under normal conditions.
Pin number 1: (H), 2: (K) = -2500V, 3: (G1) = -2500 V, 4: (NC), 5: (Q1-) = -480V, 6: (P2) = 40 V, 7: (B1) = 950 V,
8: (Q1,2+) = 586V, 9: (Q2-) = -380V, 10: (Q3-) = -160V, 11: (G2) = 40V, 12: (?) = 5V, 13: (B2) = -710V, 14: (H)
Thank you very much.
