I recently got an old Hameg analog oscilloscope off of ebay and it takes over 30 seconds to show a trace. I know the CRTs need to heat up a bit before they begin to work but from what I've seen on youtube, I don't think it should take this long. After it heats up it works quite well but is this long startup time due to it just being really old or should I be concerned about this. I know I should probably measure the heater voltage on the CRT, but that would require me to have to reseat the board connectors due to them being really loose and possibly shorting something to -1900V. Thanks.
