Hello,
I need to dig into the testing.
With the test we can test each channel one at a time. (I think)
But strangely it is in systematic error for the 4. Amazing because in the posts it is often 1 or 2 HS channels.
It is also strange that the rear outlet tests indicate "not connected".
I need to see if the exit card is present and well connected.
Maybe all this is coming from an HS voltage? Maybe the self-test should tell?
Frankly, yesterday after the carcass was dismantled, I spent only half an hour on it. I see this afternoon.
NB: On the post, it says that this would be a chronic failure of the channel amps. A power surge at disassembly and/or heating.
he preconise to put zeners 5.1v on the 5v and -5v, but do we simply cable them in// on the power supply or provide a resisistance. I need a schematic.
In case I go see if we can put an internal fan or something. I read that some holes are drilled to evacuate heat at the preamp level.
But before I have to make the mistake
I was also wondering, if we shouldn’t do a general reset of the memory stored with the battery.
Do a short circuit of the battery with a small resistance a few seconds (
?) I have not seen for the moment of general reset in the menu
If you have a solution do do that
cdt
