Author Topic: Osciloscope HP infiniium 54815A progam Ver: 3.5 and drivers  (Read 3568 times)
Offline radoslawTopic starter
« on: February 01, 2018, 12:02:46 pm »
Hello.
I received oscilloscopes for repair.
infiniium configuration:
mobo: AMI ATLAS III
CPU: AMD K6 200MHz
64MB SIMM RAM
and four expansion cards:
ethernet isa card
E2072 isa comunication card probably GPIB
PCI card with altera
PCI card with IDE AND FLOPY socket main chip F6550 B
Diagnosis:
- Dead HDD
- 3V baterry is also dead.
After adding external cr2023 and replacing HDD.
I was able to install Win98.
Now I`m loking for program and drivers.
I found information that it should be here:
ftp://ftp.keysight.com/callpub3/ddt/scope/548xx/Upg_Rec/
But the catalogs are empty.
Will there be any good man who has files from these catalogs somewhere and would be willing to share them with me?
Sorry for my bad English.
« Last Edit: February 01, 2018, 12:05:50 pm by radoslaw »
Offline Daxxin
Re: Osciloscope HP infiniium 54815A progam Ver: 3.5 and drivers
« Reply #1 on: February 03, 2018, 04:17:35 pm »
Offline abeasley
« Reply #2 on: March 09, 2018, 08:36:49 pm »
I've run into a similar problem.  I've been searching high and low for the software but the closest I found was an empty folder on Agilent's FTP site.  I'm not sure if that link will work since it was for the 54824A and possibly different hardware.  Mine is a 54815A with a US381xxxxx serial.
Does anyone happen to have a backup of HP's software somewhere?
Offline TRN
  • Country: pt
« Reply #3 on: March 29, 2018, 11:25:29 am »
If you send a nice email to the Keysight support team they will upload the software for you on the FTP.
It will stay there for +/- 7 days, and then it will be deleted
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #4 on: March 29, 2018, 03:03:49 pm »
I have the software hosted on my OneDrive here https://1drv.ms/f/s!Amqar8_XQ9Uzj6YhN1xHdM8tQdKMOA - Documentation is in the PDF in that folder.
TonyG
Offline lyncse
  • Country: ru
« Reply #5 on: September 09, 2018, 12:35:18 pm »
... necrobumping this thread
I think it may be useful to point to the fact that ancient BIOS on these m/b has a network boot capability which frees end user from need of gutting scope on every backup/reinstallation or the need of purchase parallel-port CD-ROM. Short explanation for the modding procedure is available by a link below. Also please note that during standalone upgrades which are meant to be hosted on C: instead of zip-drive, the location of the upgrade data should be equal to c:\scope\upgrade\scope\temp\, otherwise the upgrade will fail permanently.
http://xdel.ru/downloads/548xx/netboot-mod/mod-52820a.txt
Offline pawlowski
« Reply #6 on: May 28, 2019, 10:05:49 pm »
hi, does v3.5 work also for older AMI (not fic) motherboards?
« Last Edit: May 29, 2019, 07:33:44 am by pawlowski »
Offline Jacek
« Reply #7 on: May 31, 2019, 10:26:29 pm »
Probably not, this is the reason that he sold the oscilloscope on Allegro.
