Author Topic: Pics of 20Hz, 1KHz, 20KHz amplifier signal. Why is the signal shape different?  (Read 1229 times)
Offline olegauTopic starter
It seems to me that the waveform should not change from 20 to 20,000 hertz, but my Yamaha CA-700 amp shows distortion at 20 and 20,000 hertz.
Who knows, maybe this is normal?
« Last Edit: January 08, 2025, 06:59:20 am by olegau »
Offline __greg__
just use sine test signal.
for square signal it is "normal" and will vary depending on settings for bass/treble knobs....
Offline RoGeorge
This forum is for writing in English only, please use a translator and post your questions in English.
The following users thanked this post: BILLPOD, Analog Kid
Yes, I believe the amp is in good working order. The sinus signal is fain.
A good site: https://sound-au.com/articles/squarewave.htm
Offline Haenk
Maybe filter caps?
Work through the service manual is your best option:
https://elektrotanya.com/yamaha_ca-500_ca-700_amplifier.pdf/download.html
Offline CaptDon
  • Country: is
Haenk, not a filter cap problem, why suggest? The scope shots clearly show rolloff when tested at 20HZ and 20KHz. Audio amplifiers are not designed for squarewave testing. In order to have a good representation of a 20KHz squarewave the amplifier would have to be flat out to around 200KHZ, don't see that spec very often. To show a good squarewave at 20Hz the amplifier would need flat response down to nearly D.C., don't see that spec very often either. Test with SINEWAVE please.
Offline bdunham7
Actually, square waves are great for testing audio amplifiers as long as you know what you are looking at and not expecting them to remain square.  For example, the OPs signals all look really good
Offline bdunham7
Yes, those look good.  I assume there's a subsonic filter on or the amp doesn't go to DC.
I tried another Yamaha CA-700.  The form of the signals is similar so nothing wrong with the amp. This amp has excellent sound, similar to CA-800, CA-1000.
Offline Zero999
  • 0999
In the 20Hz waveform, the low frequency elements are being attenuated. I don't know what the lower cut-off is supposed to be. This might be normal, or a sign an AC coupliing capacitor is failing, since it does appear as though the lower frequencies are being attenuated a little more than I'd expect, going by the waveforms I get when putting a 20Hz square wave through different low pass filters in the LTSpice simulator.
What's the setting on the bass control? Does setting it to the maximum help?
What does the other channel's outout look like with a 20Hz square wave on the input?
The 1kHz waveform is fine.
At 20kHz, there's some slew rate distortion and loss of high frequency content. Your 20kHz square wave is not just 20kHz. It has much higher frequency harmonics: 30kHz, 40kHz etc. Your amplifier can't handle the fast rise and fall times of the square wave, hence why they show as diagonal lines on the trace and the edges are rounded. This is normal. It's amplifying the 20kHz component properly.
I'll post some simulated waveforms later.
All tone controls are flat position.
Offline Zero999
  • 0999
I've simulated an amplifier with a low cut-off of 16Hz (due to C1 and R1) a gain of 10 (Avol=10) and an upper cut-off of 30kHz (GBW = F*G = 30k*10= 300k). The slew-rate is 10MV/s which should be fast enough, not to affect the result.
Schematic.
20Hz
1kHz
20kHz
Conclusion: the plots look similar to your oscillograph, so the channel you're measuring is working properly.
The .asc LTSpice file with the frequency set to 1kHz.
« Last Edit: January 13, 2025, 06:34:30 pm by Zero999 »
The following users thanked this post: 2N3055, bdunham7, olegau
Offline Greybeard
Perfect match!  :-+
fc=1/(2*pi*R*C)=1/(2*3.14*100k*100E-9)=15.9Hz
Your Amp ist specified 15 Hz - 50 kHz /-3dB ( https://audio-database.com/YAMAHA/amp/ca-700.html ).
« Last Edit: January 14, 2025, 12:04:52 pm by Greybeard »
Thanks! I can sleep well:)
