I'm repairing this 10VA output amplifier circa 80's?
The amplifier drives a transformer and operates in the 50-500 Hz range
The Q7 output 2N6385 has failed (TO-3) package I normally order from Digi-Key, or Mouser however this part is not stocked, and the non stocked part is priced at $65 a pop minimum 100, not going there.
The NTE245 looks like a good substitute, however neither Digi-Key or Mouser have that either.
Any suggestions for a viable substitute from D-gi-Key or Mouser?
[ Specified attachment is not available ]
