Hello Guys,
I got a Magnetic Stirrer Hotplate from ebay with a broken temperature control going so cheap I thought it would be worth a punt.
Got it on the bench today and tested it out, as described, everything works apart from the temperature control, the plate heats up but cant be adjusted, and the control pot just keep turning and turning.
I stripped it down, and assume the problem is the Simmerstat (something I have never worked with before).
The Part is a Diamond H Controls LTD 31ER1TF 45, with tabs for
Line,
Load A,
Neut, and
Pilot,
Load B (not connected)
I googled he part number and found a this:
http://www.amazon.co.uk/UNIVERSAL-REGULATOR-SIMMERSTAT-COOKERS-APPLICATIONS/dp/B00J5JOX64That states it replaces Diamond H 31ER1TF
Should I order this one, or am I missing something important here?
