Author Topic: OWON SDS 1104 power issue  (Read 415 times)
Offline analog proTopic starter
« on: September 07, 2024, 06:49:49 pm »
Hello everyone. My oscilloscope has the issue of not turning on. Anyone with its pcb layout or  schematic diagram can send it to my email analogpro762@gmail.com. Thanks in advance
Offline BlownUpCapacitor
  • I kinda suck at the art of electronics tbh
Re: OWON SDS 1104 power issue
« Reply #1 on: September 08, 2024, 06:44:39 am »
Usually, schematics are not available for these scopes.
Did you measure voltages on the power supply?
Hehe, spooked my friends with an exploding electrolytic capacitor the other day 😁.
« Reply #2 on: September 08, 2024, 09:22:29 am »
yes. I measured the voltage and is as required, 5.7V.
« Reply #3 on: September 08, 2024, 09:24:45 am »
The issue is that the screen is not displaying anything. How do i fix it?
Offline Gyro
« Reply #4 on: September 08, 2024, 01:16:05 pm »
Try a performing a factory reset - no I don't know how to do it on that model, you'll need to find it in the manual or web search.
Best Regards, Chris
« Reply #5 on: September 08, 2024, 06:04:51 pm »
Does the owon use a backlit LCD? If so, check the backlight.
Maybe wiggle the display connector around and see if that helps.
If you have another oscilloscope, probe one of the display data lines and check for activity.
