Author Topic: OWON VDS1022 CD Eye pattern  (Read 1560 times)
Offline abhi1981Topic starter
  • Country: in
« on: November 26, 2022, 09:03:28 am »
Hello,
Just got an OWON VDS 1022 from Amazon for around $87 (INR 7125). This is my first oscilloscope.
An analog scope would have been better but couldn't find one. The ones available were either expensive or badly abused.
Connected it to my Yamaha CDC 635 for an eye pattern and the result is shown in the below image. It sometimes starts skipping CDs.
I think the refresh rate at infinite persistence is quite slow. What do you think ?????  :-// :-//
I have also attached a link to the video showing the eye pattern at different persistence settings.
https://youtu.be/DVgZDktMNmk
I have connected the probes via jumper leads, as the test points were under the tray and impossible to reach. Otherwise, the board will have to be taken out.
« Last Edit: November 26, 2022, 02:29:56 pm by abhi1981 »
Offline Manolo Mos
Re: OWON VDS1022 CD Eye pattern
« Reply #1 on: November 26, 2022, 05:49:36 pm »
Hi. The oscilloscope looks to perform well. The first image is correct to see the RF signal. The RF signal looks to be noisy, maybe it needs to correct Focus Offset adjust. But I insist, oscilloscope looks to be OK, RF is noisy, laser pickup is giving a noisy signal.   And yes, sometimes is not easy to get RF signall with a probe.  Attenuation by 10 is recommendable too for to see RF signal in CD laser pickups.
The following users thanked this post: abhi1981
Online Audiorepair
« Reply #2 on: November 26, 2022, 06:57:03 pm »
An analogue scope would not have given you that amount of detail.
Good choice.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: November 26, 2022, 07:52:36 pm »
OWON HDS242 is very fast update rate. $100+ (add only few dollars), 40MHz, 250MSa/s, portable and no need PC, DMM mode..
Online Gyro
« Reply #4 on: November 26, 2022, 10:02:27 pm »
Wow, a whole 3.5" 320x240 display, awesome!  ::)
Best Regards, Chris
Online Audiorepair
« Reply #5 on: November 26, 2022, 10:15:23 pm »
Despite the noise, its not hard even for a human to tell the difference between a "1" or a "0"  from this data.
  • Country: in
« Reply #6 on: November 27, 2022, 09:15:51 am »
Thanks everyone for your valuable comments.
Maybe the noise is caused by the jumper wires. I'll try using a shielded wire.
The CD tray is also very sluggish. Changing the belt didn't help. Greasing the gears and rails also didn't help.
The motor controller IC TA7291P also becomes quite hot.
  • Country: my
« Reply #7 on: November 27, 2022, 09:45:39 am »
for a long time i was eyeing portable scopemeter things like hantek 2000 series https://www.eevblog.com/forum/testgear/hantek-2c422c722d422d72/?topicscreen and others tablet and china cheap scopes, but their GUI look very basic, some has one channel only and slow update rate is the common one etc. when i saw Hantek HDS 200 series https://www.eevblog.com/forum/testgear/owon-hds-200-handheld-oscilloscope-w-builtin-dmmawg/msg3451228/#msg3451228 i thought this is it, the update rate is one big step ahead, so i punched the button and get 500MSa/s HDS2102S for a bit more than $200 (since i think its time to get one such portable scopemeter unit), and then later came 1GSa/s HDS2202S for a bit more. this scopemeter reminds me of my DS1052E except with basic edge triggering method (which is standard among all portable scopemeter i've seen anyway)... imho people should search in eevblog first before risking buying relics or the wrong item in the market, unless they have very specific reason. but i think eevblog has expanded with many threads everyday that even seasoned members can miss lots of recent news, ymmv.
The following users thanked this post: Gyro, abhi1981
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #8 on: November 27, 2022, 01:44:51 pm »
What you have on the screen is not an eye diagram. For that you need to trigger on the regenerated sample clock.
What you're seeing there is just a data signal. It's hard to say anything about its quality like this.
The following users thanked this post: gf, abhi1981
  • Country: in
« Reply #9 on: December 05, 2022, 08:31:37 am »
Returned the scope as it was hanging up and the lagging was quite annoying.
Back to square one :( :(
Now, I'll have to look out for an analog scope.
« Last Edit: December 05, 2022, 08:33:10 am by abhi1981 »
  • Country: my
« Reply #10 on: December 05, 2022, 08:40:58 am »
good luck!
