Many screws appear yellow, like the one attached.
If I am not wrong, they are known as chrome plated. To my (very limited) knowledge, however, chrome plating is for having a shiny, silver like color.
What do they add that makes them yellow?
I had some oxidized screws (the oxide was white) from a 1982 sega console. I used acetic acid to strip the oxide. This removed the plating as well, so I plated them with nickel. This clearly changed the color to gray, and I would like to restore them to the original color, how can I do that?
And, is there something other than acetic acid that only dissolves the oxide but not the plating itself?
