Author Topic: P6106 probe 10x pin assembly  (Read 1406 times)
Offline ledtesterTopic starter
« on: April 01, 2016, 12:20:45 am »
The 10x contact pin assembly on my P6106 Tek probe mysteriously came apart, and I'm wondering if it is fixable. Somehow the black retention ring came off and I heard something drop on my hardwood floor.
Below are some pics of the pieces that I've got. I have a feeling that I am missing something. The second pic is how I think things are suppose to go back together, but the 10x pin isn't being pushed out to make good contact with the 10x ring on my 475.
Any ideas?
« Last Edit: May 02, 2018, 04:00:21 pm by ledtester »
Online Andy Watson
Re: P6106 probe 10x pin assembly
« Reply #1 on: April 01, 2016, 12:42:08 am »
I'm guessing that you are missing at least some sort of spring to push the pin out. Some Tek probes use "pogo" test pins to make the contact - this might be a source of parts if you can't find the original spring.
