Author Topic: Weller PU81 PIC16F1503 firmware dump needed.  (Read 2116 times)
Offline badyl00Topic starter
« on: February 11, 2020, 12:45:30 pm »
Hello. I have weller PU81 station with burned microcontroller. There is PIC16F1503. Maybe someone can read firmware from it. Also need value or marking of ic and diode marked in attachment. I desolder it some time ago and it's gone now  |O.
Offline mariush
Re: Weller PU81 PIC16F1503 firmware dump needed.
« Reply #1 on: February 11, 2020, 12:52:24 pm »
The chip's firmware is most likely protected, meaning you can't read it.
If you're really lucky, maybe you can contact Weller and ask them to send you one pre-programmed chip, or a whole replacement board (that may cost you some money)
As for your other questions, this seems to be the service manual which includes schematics : https://elektrotanya.com/weller_pu81_schematic.pdf/download.html
« Reply #2 on: February 11, 2020, 01:01:48 pm »
Probably weller do not protect their chips. Schematic from link is a old hardware version. Newer its on uC. I tried to contact weller but they don't want to help.
I attach a photo with pinout for programming.
Maybe someone have this version of station and can read firmware and fusebits.
« Last Edit: February 11, 2020, 01:08:47 pm by badyl00 »
« Reply #3 on: February 18, 2020, 12:25:56 pm »
I drew a schematic of this scrap. I'm not sure about U2. It have marking SAGK and SOT-23-5 package.
« Last Edit: February 18, 2020, 04:26:55 pm by badyl00 »
« Reply #4 on: February 18, 2020, 02:43:23 pm »
Searched a lot of datasheets and probably it is a MCP601 in SOT-23-5 package:
http://ww1.microchip.com/downloads/en/devicedoc/21314g.pdf
Schematic updated.
« Last Edit: February 18, 2020, 04:32:11 pm by badyl00 »
The following users thanked this post: fzabkar
« Reply #5 on: February 27, 2020, 08:32:08 am »
In attachment firmware readed from another station. After replace 100% working. Program with MPLAB. Op amp is MCP601 and zener diode 8,2V.
The following users thanked this post: coromonadalix, tooki, fzabkar, YetAnotherTechie
