Hi Guys
The left channel of my power amplifier doesn’t work properly anymore. Sometimes it works and sometimes it doesn’t. It’s not scratchy at all. I’m sure the pots ( volume control) aren’t the problem. The right channel is fine so I guess there is nothing wrong with the power supply.
The sound on the left channel doesn’t fade out, it just stops. Turning the volume control won’t help. If I power the amp off and then on again, It works fine again. (most of the time)
I don’t know if it is the protect circuit or maybe a bad capacitor or transistor which could be the problem.
Does anyone have any suggestions for something that I could measure?
I do know quite a bit about electronics, but with this problem, I don’t know where to start.
Hope someone has an idea?
