I recently got a tektronix 475 and after replacing all of the filter caps and all of the underrated tantalum capacitors, the 15V rail is still not working. I narrowed the problem down to the +15v unreg rail which is also low but I don't know exactly what the problem is. I initially suspected the bridge rectifier but after testing it with my oscilloscope component tester against a working rectifier, it appears to be working. I also tested the +15v unreg rail without the fuse going to the crt circuit and removing power from all boards besides the main board but the problem was still there. I don't know what could possibly be making the +15v unreg rail go low so maybe the rectifier is actually toasted. There is ~18VAC on the transformer winding so thankfully I think the transformer is fine.
Supply voltages
+50V 50.0V
+110V 111.3V
+15V 1.7V
+5V 4.7V
-15V -3.2V
-8V 0.4V
+15V unreg 0.4V
+50V unreg 71.9V
+105/160 10.7V -multimeter might be broken as 146.4V appears later down the circuit
Supply resistances all from + to -
+50V 2.73k
+110V multimeter can't decide
+15V 64
+5V 23
-15V 12.51k
-8V 32
+50V unreg multi meter can't decide
+105/160 no resistance or greater than 2M
-8V and -15V are regulated by +15V, so it is expected that they wouldn't work. As for the resistance either my scope is very messed up or my cheap hardware store multi meter is acting up. There was definitely a bad filter cap and some shorted tantalums on the +15V rail which may have cause the mains fuse to blow before I got it.
Thanks for the help
