Author Topic: Packard-Bell Model 621 Radio Ground Safety  (Read 533 times)
Offline ScottmanTopic starter
« on: September 27, 2020, 08:03:00 am »
I am starting into electronics, emphasis on old radios. I was given the PB Model 621 but was told to be very careful since I would have a 50-50 chance of plugging it in and having the chassis be hot. Given that, is there a way to change the power cord and have one with the larger spade to minimize this potential hazard? Bottom line is I don't want to kill myself when I plug the radio in. Thanks for being here as I just found this site and joined.
Offline iteratee
  • Computer Engineer
Re: Packard-Bell Model 621 Radio Ground Safety
« Reply #1 on: September 27, 2020, 09:08:53 am »
It's using a shared chasis-neutral. You need to separate them so there's a dedicated earth ground and have the chasis connected only to earth, not neutral. This is rather critical to fix before use.
« Last Edit: September 27, 2020, 10:30:58 am by iteratee »
