Author Topic: Help with diode identification  (Read 494 times)
Offline MartinrTopic starter
« on: September 18, 2022, 10:40:50 am »
A diode has failed on a Panasonic microwave circuit board.   I believe the diode is part of the mains rectification section.   I can’t find a schematic for this model.
There are only 4 characters on the diode: zero, 6 and then two characters on their sides, which could be sixes or nines.
I have copied these characters onto paper as they appear and also show 2 photos of the diode.
I’d be grateful for any help in identifying it or a suggestion for a replacement.
« Last Edit: September 18, 2022, 10:43:23 am by Martinr »
Offline m k
Re: Help with diode identification
« Reply #1 on: September 28, 2022, 03:54:55 pm »
Put a new one that is enough.
Numbers could be 0.6*1000V 6A, 9A peak.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline fzabkar
« Reply #2 on: September 28, 2022, 10:14:21 pm »
I would locate a service manual for a similar Panasonic microwave oven and then identify a diode with the same function.
Plenty here:
https://elektrotanya.com/showresult?what=Panasonic+microwave&kategoria=All&kat2=All
