Hello, Goodwill special for 2.99 I scored this VCR in great shape. Plugging it in shows the clock turns on, but everything is unresponsive. Will not power up, and nothing happens when you try to insert a tape.
Upon reading sounds like these machines have power supply issues, mainly leaky electrolytic capacitors. Upon opening it, quick check of the power supply shows there may be one or two bulged caps. So I plug the machine in and test the outputs of the supply to the main board. Based off this schematic, here's the outputs I get for outputs:
https://www.repairfaq.org/sam/vcrps.pdf1) +4.24v
2) +51.4v
3) +17.32v
4) -1.6mv
5) +4.28v
6) +4.28v
7) -35.6v
-28.02v
9) -25.84v
From what I read, if the 5v rail is any lower, the machine will have issues.
It appears someone has tried to repair this power supply in the past, however with the wrong components. By the schematic C16 was originally 6.3v 330uF, was replaced with a 25v 330uF. Which should be fine as far as I know. However both C11 and C14 which should both be 50v 10uF were replaced with 50v 4.7uF. Which could be the problem totally. Plan of attack; Order all replacement electrolytic caps (C4, C11, C12, C13, C13, C14, C16, C17, C19, & C21). Also replace Zener diode D15 which according to what I read is destroyed when caps go bad.
My next problem, and it was completely my fault. So when I was testing voltage output, I accidentally touched my multimeter leads together when I was measuring between outputs 3 & 4. Which dead shorted 17.32v to ground. It was a split second, but I saw a spark, and damage was done. ugh. Now the power supply makes a terrible whine when plugged in. What I have done: Removed C12 and C13 for time being. Also removed and tested the power diode D6 out of circuit. When removed, the supply mo longer makes the wine sound. However the diode tested ok I believe. (dmm leads one way 57kohm, the other way reading bounces between out of limits and 16mohm. Did I zorch the transformer? Where should I text next? I hate when I f something up more than when I started, but, i'm sure it can be fixed.
Thanks for any help!!
