Author Topic: Panasonic Relay Marking  (Read 571 times)
Offline chick0nTopic starter
« on: December 29, 2023, 08:05:28 pm »
Hi
Im wondering about Panasonic / Nais brand Relay markings.
For example, there are RF-Relais marked:
RK1-L2-5V, but some are marked  RK1-L2-5V-H51, or  RK1-L2-5V-H23.
What does the "H" marking mean? I couldnt find any information in the datasheets.
I also found this on other series from panasonic: JJM2W-12V, JJM2W-12V-H52...
Re: Panasonic Relay Marking
« Reply #1 on: December 30, 2023, 11:02:32 am »
I found this:
https://forum.digikey.com/t/panasonic-hxx-suffix-information/1909
"the Hxx suffixes are custom parts and the part numbering is not standardized. This can be a simple as a custom part marking and can be more complicated with plated up/down version or high temp epoxy. It is possible that the standard part will work, however if for example it is a high temp epoxy the replacement part may not be suitable for the application."
« Last Edit: December 30, 2023, 11:27:38 am by chick0n »
The following users thanked this post: fzabkar
