Author Topic: Panasonic VP-7725D Audio Analyzer distorted oscillator  (Read 1291 times)
Offline Ray GianelliTopic starter
« on: January 16, 2021, 02:48:23 pm »
My distortion analyzer has started to output distorted waveforms at the oscillator output.  While it at first appeared that this unit has two totally independent channels, it looks like they share a common oscillator.
Compounding troubleshooting issues is the fact that the construction of the unit makes it virtually impossible to do any power on testing.  The oscillator/attenuator assembly is on a plug in board beneath 2 other plug in boards.
Attached is a pic of the distorted output.
Here's a link to the service manual, which is impossible to find.  Thankfully I got a copy when I purchased it:
https://drive.google.com/file/d/0BxLVd1MVhl--ZTBMazRZd3RhWDg/view?usp=sharing
Any help with this would be greatly appreciated!
Offline schmitt trigger
  • Country: mx
Re: Panasonic VP-7725D Audio Analyzer distorted oscillator
« Reply #1 on: January 16, 2021, 03:17:43 pm »
Are the board connectors a standard type?
If so, you will require to build extension patch cables, which will allow you to have all the boards spread out on the work bench.
« Reply #2 on: January 16, 2021, 03:24:20 pm »
I've looked into that.  They're available from most online vendors.  The sockets on the backplane are Omron XC5B-6421, 6422 on the board, 2 of each required.  Fortunately I just need the one board on the bench.
« Last Edit: January 16, 2021, 03:58:40 pm by Ray Gianelli »
Offline USMC_Spike
« Reply #3 on: February 03, 2021, 08:40:02 am »
I was looking for the pop corn guy to watch as you go along.
Yes, there it is with a drink also.   :popcorn:
It's hard to get most of the Matsushita manuals for their gear.
Heck I never found a service manual for the VP-7635p so there is
sits. The -p is for Panasonic, -A for National, and I think -m was for
Matsushita.  I can find a $100 parts unit but shipping is 250.
I did find this manual number, don't know if it's correct,
VP-7635A nat-qvp7635a.
I put it here so I could find the number again.
I think I only need the four latching input signal switches for
the meter to work, of course I don't have them.
Good luck and hope your repair goes well.
Spike
« Last Edit: February 03, 2021, 08:44:50 am by USMC_Spike »
Cheers,
USMC_Spike
