Yes, I also found out about the data transfer, the electronic load needs request for response.
This software is well tested and works in China, on Chinese Windows. If you replace the default Windows language to Chinese, the program will stop issuing errors to "
?.vi" libraries. I think references to these libraries contain hieroglyphs.
But! The program works, but not quite ... COM port connections gives an fault plus some hieroglyph)))
P.S. I think need will made new software by some simple base, because Lab View so big and hard for so simple task.
