Hi! First time poster here but a long time lurker and an even longer viewer of Dave's videos on Youtube. This is such a great community it really made me take an interest in electronics and grab my first soldering iron and so far so good.
A few months ago my 4 year old GTX 580 died, I wasn't really surprised because the card was showing signs of being near it's life span (artifacting etc.) and I even baked it once when it stopped working completely and managed to get another 5 months use from it. Being that I started college and didn't have time ti play video games anymore I decided not to spend money on a new graphics card and just stuck my old 8800GT into the PC as it was more than enough for my needs.
Today my 8800GT too has stopped working it seems, this struck me as odd as even though the card was old (bought it back in early 2008) it was never used a lot. Not wanting to come to terms that 2 GPUs died on me in the past three months I decide to try and find out what might be the reason behind this, so I power cycle my PC (unplug, press the power button on of for a minute plug back in), try another cable from the PSU, try a different PCI-e slot, everything to no avail. At one point I unplug the DVI cable from the back of the PC and while plugging it in to a different DVI port (the 8800GT has two) I notice a very small spark.
The spark appeared between the metal "casing" of the DVI port on the GPU and the same metal casing on the DVI cable from the monitor, which if I am correct both serves as ground contacts between the GPU and the monitor. I have no idea why there would be any voltage between the monitor ground and the PC/GPU ground, I have a safety extension cord where both my monitor and PC are plugged in so I wouldn't think it would be the problem. I've just recently redone the grounding in my house as it is pretty old but even before I did all of my other sensitive electrical equipment worked fine. I'm not sure if even this small sparking between the monitor and gpu ground contacts could be the reason for the graphics card dying.
