Hello everyone. So I got this PC steering wheel, Thrustmaster T500RS. And recently it started cutting out during gameplay. At first it was intermittent, now it's unusable. I've noticed that power adaptor light cuts out too but it starts working again when I unplug and wait for a minute or two. So naturally I thought that adaptor is failing. But before going for a new adaptor decided to do some googling maybe someone else had this issue. Found post with same issue, plus he noticed when he turns his wheel, power adaptor light turns on even if adaptor is disconnected from main power. He sorted his problem by getting new board from Thrustmaster support. I've noticed that my steering wheel does the same (video:
https://youtu.be/-NCU9CslhAI). So my question would be , what internal part on PCB could cause power from motor being sent back to PSU?
What I've done:
Searched TM knowledge base, and found this:
Does the wheel shut down during gameplay? If the wheel is still shutting down during gameplay and the LED of the adapter turns off as well, then steer the wheel in big circles when this happens and check if the LED on the adapter has a flickering light.
If the power supply works fine by itself but when connected to the wheel it has this behavior, please contact us via phone or e-mail and we will further assist you with this matter.
I've wrote an email in hopes they could point me to right direction. Still waiting for response.
I disassembled wheel and tried checking mosfets (P120NF10). Desoldered and checked with multimeter, readings where fine. Noticed that mosfets where tinkered with before and one of them had different serial number from the others. I also checked diodes, but didn't remove it from the board, readings where also fine. Ended up ordering new mosfets, just in case.
Any input would be greatly appreciated.
" alt="" class="bbc_img" />
