Author Topic: PCB conformal coating  (Read 1133 times)
Offline gobo207Topic starter
« on: January 30, 2020, 12:42:19 pm »
Hi All,
I recently repaired a PCB from an air conditioning unit compressor. Some of the tracks had blown and an arc made its way across a good 8mm gap burning the fiberglass.
My question is, once I ground all the carbonized fiberglass away and strengthened the leftover track with de-solder wick and solder, do I need to put a conformal coat back on? And if so, what should I use?
Thanks,
Offline aqibi2000
Re: PCB conformal coating
« Reply #1 on: January 30, 2020, 01:06:52 pm »
PCB Lacquer
Tinkerer’
Offline Zucca
  • EE meid in Itali
« Reply #2 on: January 30, 2020, 01:42:04 pm »
to fill up the hole epoxy should be fine, I think.
To repair solder mask
cheap, nail polish transparent
Pro choice, UV PCB lack
https://www.amazon.com/Curable-Solder-Repairing-Paint-Green/dp/B01MUB4PJL
Offline Silverbackaircon
  • Country: sg
« Reply #3 on: May 25, 2020, 02:08:26 pm »
PCB laquer is the better choice in my opinion.
Fyi we do Aircon PCB repair and Aircon Gas top up
« Last Edit: May 25, 2020, 03:01:52 pm by Silverbackaircon »
