AC has less resolution so it's hard to tell.
Seems to be a bad contact issue.
When I turn the dial from V to Ohm usually it shows 0 Ohm, in seldom cases it was also showing significant resistance.
But usually when I go from the Ohms setting to the V setting it has a value of a few mV only, as it should.
You can see how it quickly goes from 300 or 600mV to almost zero almost instantly.
So I think it's a bad contact/issue with the dial.
Though when I leave it on the volt setting, the voltage slowly rises, so it's probably a bit more complex.
The COM plug solder joint is broken, I will fix it and see if it makes a difference.
