Author Topic: PeakTech 4120 generator failure  (Read 608 times)
Offline ferdieCXTopic starter
  • Country: uy
« on: October 26, 2023, 09:06:04 pm »
Hi to all,
In the university where I teach, we have a PeakTech 4120 that is failing to properly startup.
It is a chinese product that probably sells under other brands. I have seen a two channel model rebadged as Tektronix
Does any one of you have any technical information or clue about this device ?
Thank you in advance
Online coromonadalix
Re: PeakTech 4120 generator failure
« Reply #1 on: October 27, 2023, 04:49:05 pm »
could be his one ?
In their 1000 series
AFG1062
must be similar to the AFG1022 series ??   but tek on their site have multiples warnings of  not messing with the wrong model ???   do not flash on 1062  etc ...
Anything can be done under the hood,  change the front panels pcb ...  remove some buttons etc ....  rebrand it and voila ?
can you open the case and show us any pcb markings
with free registration   you have acces to their FW   but no 5 Mhz model as far as i know
downloaded their 1022 fw
1.21
1.22
1.23
1.24
1.27
« Last Edit: October 27, 2023, 05:09:37 pm by coromonadalix »
« Reply #2 on: October 27, 2023, 05:00:32 pm »
reserved 1
« Reply #3 on: October 27, 2023, 05:01:28 pm »
reserved 2
1.27
Maybe you can  or someone else can extract the boot files ??? or help you
is it under warranty ??
have you contacted Peaktech ??
« Last Edit: October 27, 2023, 05:03:03 pm by coromonadalix »
Offline The Soulman
  • The sky is the limit!
« Reply #4 on: October 27, 2023, 05:18:28 pm »
It's not a tek, it's a Owon, likely "inspired" by the tek design.
https://www.owon.com.hk/products_owon_2-ch_arbitrary_waveform_generator_without_counter
The following users thanked this post: coromonadalix
  • Country: uy
« Reply #5 on: October 28, 2023, 01:35:34 am »
Although it was almost never used, the instrument is about two and half years old, so no warranty
I opened it, and it is not very service friendly.
You have to dismantle it almost completely to gain access to the board.
« Last Edit: October 28, 2023, 01:38:32 am by ferdieCX »
« Reply #6 on: October 28, 2023, 01:45:38 am »
wow  what a strange setup
an arm cpu module  ??? year 2010  is that it ???
maybe some Owon FW updates ??
thread of it  here
https://www.eevblog.com/forum/testgear/owon-ag1012f-arbitray-waveform-generator/
you see the pcb hardware ...  only thing i see,  there is a 3 pins  holes in row and we see TX RX  on them,   maybe some console port ??
« Last Edit: October 28, 2023, 02:02:24 am by coromonadalix »
The following users thanked this post: ferdieCX
