Hello Folks,
I'm also new to this group and joined.. based on a problem I have with my Peavey Classic 30. My knowledge about electronics is limited. The problem I have is this: a few months back my amp started to drop out occasionally, usually after 20-30 minutes of playing, in a way similar to a weakening battery in an FX pedal (I use 4 pedals max, all battery-run), losing volume over roughly 30 secs to 1 minute, until no sound could be heard. This happened more often lately. Today I noticed that the power supply to the valves was dropping and slowly going off. The filaments would slowly stop lighting up.. while the pilot light remained on. - Using the simple 1st test method of kicking the amp slightly the power did come back on, but only briefly. The output valves are fairly new, the pre-amp valves not. The reverb hasn't worked in ages but that seems to be a circuit separate from the valve circuit (this I learned from this forum ..so, thank you very much. I have already learned something new..). - I should add that the amp made a rumbling, rushing kind of white noise before this new problem occured, sounding like the output valves were on the way out, but they are as I said fairly new. Does anyone have an idea what the problem could be? I have a MM but I don't know enough about what to measure where and how. I will study this matter further but perhaps someone can give me advice on what to look for. Should I replace the 3 x 12AX7s (the filaments in those remain 'on'...so that doesn't seem to be the problem, but...) ? Thank you.
