Had two bad pots on the front dials, got those replaced and channel B on the amplifier is perfect. Channel A, however is less than so. It almost sounds like clipping in the circuit; as the volume is turned up the sound becomes very distorted, I can bond the two channels and use the input in channel A, but the output on B and everything sounds fine. It has to be something in the amplification circuit, I've tried finding a service manual or a schematic for this unit but no luck. Any body have any previous experience with these units ?
