I've taken up fixing amplifiers for fun! Anyway I've managed to fix 24 of 25 so far and I think that we could probably all guess that the one I haven't yet managed to fix is the only one where "my mate has already had a look and says it's knackered"....
Anyway I got it partially working before slipping up and shorting out of the transistors in the output section. I've fixed that now with two new power transistors. The issues were many and included dirty pots, 2 knackered poly caps (I've replaced all of them now), a transistor removed by his mate to test and re-inserted the wrong way! plus lots of other rubbish......
It now works BUT there is a loud 100hz hum. It is as loud as the input signal! If you switch it off at the isolator the hum goes but the input signal continues till the caps loose their current. The actual signal is nice and clean otherwise. I’ve pushed music through it as well as test tones
I've attached a schematic and I'm sure it's coming from the mains being twice the UK 50Hz.
I've replaced the 10nF cap across the bridge rectifier, both 2200uF caps (C52/54) and C53/55. None appeared to be faulty according to my Peak cap tester but grasping at straws now.... All other caps measure well within tolerance and low ESR. All polys have been changed as I mentioned earlier. All the transistors have been tested and having discovered that U5 isn't required to get a sound I've tried it in place of the other op-amps of the same type. U3 is an op-amp I don't have and I'm not sure what I could substitute it with (even if just for testing).
All pots have been removed dis-assembled cleaned, de-oxitted, re-assembled and tested and are like new.
Input jacks are new high quality ones
Any help would be appreciated even if just pointing me at other things I may not have thought of. I am quite new to amps having come from computers so I might have missed something obvious!
