ultrasonic it with simple green and rinse with alcohol and it will be good. I don't know how resistant the plastic is to alcohol, I would not advise a long alcohol dip. I think the simple green + ultrasonic has a slight deoxidizing effect too, more so then simple scrubbing, for whatever reason.
I usually get black snot, that one looks pretty decent actually, as far as bad pots I have seen
These work well on the coils without hurting them, after its been loosened up by ultrasonic I poke it with the 3rd brush in the picture from the left and then put it back there, run it under running water for a while, put it back in there, brush again, rinse good, squirt with alcohol so it pours out of the pot, shake it 'dry', let it dry the rest of the way and then deoxit in solvent then deoxit grease. I figure just putting thick grease in there will not entirely coat the thing. When you put grease wipe it around with another brush and smear it on the metal parts in there too.
https://www.amazon.com/Plastic-Handle-Keyboard-Cleaning-Black/dp/B076HP2TYBI often wonder if a dip in HCl might help but I never tried. I really like putting as little money as possible into old equipment because you never know what the hell is gonna break and it can turn into a money pit if you are not careful (i.e. transformer).
You might also want to desolder the transistors, polish them up and reseat them with grease and new pads in those. I found the insulator sheet to be covered in like a oily liquid before, I think capacitor leakage got up in there. I rinse the whole PCB after it sits for simple green for 5 min then blow dry with an air gun because their usually disgusting and change color. That top side vent leaves the harrisons filthy. If you read my thread I put one with pots and everything into the ultrasonic after removing the panel meter and it was fine lol (thats not the one with the cracked trace, I was delicate with that one actually).. if you have those switches that are semi sealed, its easier to ultrasonic it panel down then take the switches apart with solder wires still attached and rinse with alcohol in a bottle then to desolder like 20 wires. One was so bad it was making smoke (tobbaco?) when I tried to desolder parts!
if you have a buzz from it don't blame the transformer immediately, it is part of the problem but the ceramic caps near the diodes are the biggest offenders, if your PSU has them.
